Motion Control and Motor Drives
Yaskawa Sigma II Servo Drive
Hi all,
I have a Yaskawa SGDH Sigma II Servo drive package. I wish to communicate with it using the PC's Serial port. The drive directly accepts one axis motion commands. I wish to know the details of the communication protocol that it uses and the list of commands that it accepts. I am using LabVIEW for development. Are there any Dlls available?
Giridhar Rajan
Cruiser Controls
Mumbai, India
Message 1 of 13
(9,135 Views)
Which motion controller is attached to that drive?  Doesn't Yaskawa offer the syntax for it?   I have used Labview with a LegendMC, which I believe uses the SMC 3010.  I used ethernet communications, but the commands were the same for the 232 port.  The SMC 3010 is really a Galil motion controller that Yaskawa puts their name on.
Message 2 of 13
(9,125 Views)
Hi Brian,
Thanks for your reply. The motion control is inbuilt in the drive itself. I don't have any motion contoller, connected to the drive. The drive itself can accept position commands via the serial port and then execute them. It has connectors for encoder f/b too. I am not able to find the syntax on the internet. I had sent a mail to yaskawa support and got no reply till now. Somebody please help.
Giridhar Rajan
Automation Engineer, Design
Cruiser Controls
Mumbai, India
Message 3 of 13
(9,117 Views)
All I can recommend is to try the commands that the LegendMC uses.  I don't have any documentation with me, but I believe the following should produce a move:
SH (turn on servo)
PA:1000 (move to absolute position of 1000 counts)
BG (begin motion)
Try them one at a time.  You should get a blinking cursor back if everything is OK.  If it doesn't like the command, a "?" will be sent back.
Message 4 of 13
(9,112 Views)
Check this out: http://www.yaskawa.com/site/dmservo.nsf/link2/TKUR-5QVLZC/$file/Application%20Modules%20Catalog.pdf#...
As you can see, there are a variety of motion controllers that can attach to the Sigma II drive.  This documument also has some serial command examples.
Message 5 of 13
(9,110 Views)
I use a SGDH sigma II with a NS600,
with a hyper terminal:
bits/s=9600
given bits=7
evenness=even
stop bits=1
flux control=none
to control it, you can use these commands:
YSVON           on
YSVOFF         off
YJOGPXXX    free runing in the positive way ( xxx always >0)
YJOGNXXX    free runing in the negative way ( xxx always >0)
YSPDXXX      speed control ( xxx always >0)
YPOSIXXX     position control ( xxx ><0)
YPOSAXXX    other position control  ( xxx ><0)
ST                  start in speed control
STOP
Y is the number (the name) given to your SGDH.
XXX is the value of the position or the speed (beware of the speed unit).
when you give a speed with SPD you must give a position with POSI or POSA and then ST.
Message 6 of 13
(9,081 Views)
Thanks a lot for your reply, Brian and Cixous . This info should do I guess. This forum rocks.
Giridhar Rajan
Cruiser Controls
Mumbai, India
Message 7 of 13
(9,060 Views)
You may also want to check out the PCI-7390 with direct connectivity to Yaskawa Sigma II.
Message 8 of 13
(9,041 Views)
Similar to PCI-7390, are there any PXI version to connect to Yaskawa drive.
Best Regards,
Bipin
Message 9 of 13
(7,938 Views)
Hi Bipin,
There is no PXI version of the PCI-7390.
Justin
Message 10 of 13
(7,916 Views)
