Motion Control and Motor Drives
When starting analysis the program unpredictably freezes.
I'm using TremorLab II Rev. 2.1. When I'm starting analysis, it unpredictably freezes and there's pop up window saying TremorLabII uses the LabView Runtime Engine that is Copyright has stopped working.
Is there any solution? Thank you for help. Igor
(3,473 Views)
Thank you for contacting National Instruments. We are not familiar with TremorLab. It appears from their website that they use LabVIEW. If you need the run-time engine it is free on our website but you would need to see which run-time engine is needed for the TremorLab's software.
Please contact TremorLab for further questions regarding support for their software products.
Vince M
(3,459 Views)
