Motion Control and Motor Drives
What is impedance of Home inputs on 7344?
I'm interfacing sensors with their own pull up resistor and want to be certain that the line will rise high enough.
(3,513 Views)
The home switches of the 7344 are designed to be high impedance inputs. So as long as your sensors' pull up resistors aren't huge, you should still be able to make out logic highs on the home switch input.
(3,513 Views)
Kyle,
Thanks for the answer, but why is this input impedance value such a secret. It is needed to determine "if the pullup resistors are huge".
Can you give me a number ?? ohms.
Bob T
(3,513 Views)
