06-01-2009 02:53 PM
I have my stepper driver connected to the +step and aogrnd terminals on the UMI-7764. With the driver connected to these terminals the output across the two is 2vp. When I disconnect the driver, the level returns to a 5vp signal. My drivers inputs are optically isolated so I suspect the impedance my be higher than TTL can drive. Is there any way to manually set the output parameters of the 7330 Motion controller?
Thx...Vic
06-02-2009 11:31 AM
Hi Vic,
Take a look at this KnowledgeBase: How Do I get the 73xx Controller and UMI-7764 to Drive a Third Party Stepper Motor?
I think it may have the solution to your problem. Also, here is another KnowledgeBase that is relavent:
Why Do I have to Supply Power to my UMI-7764?
I don't believe there is a way to manually set the output parameters of the 7330, but I don't think this is the source of the problem. If the KnowledgeBase articles are not the solution, post back and we'll keep troubleshooting!
Kristen H.
