Motion Control and Motor Drives
USB-CAN gateway with one EPOS2 P master controller and two EPOS2 slave controllers
I am using a USB- CAN hardware configuration wherein one master controller (EPOS2 P) is connected to the PC via USB and 2 slave controllers(EPOS2) are connected to the master via CAN cable. An error saying 'bad interface name' is popping up for the EPOS2s(slave controllers). I have checked the protocol stack name, the interface name and the port name for all the connections in epos studio and then gave them in the labview code accordingly. I am attaching the screen shot for the Labview code and the errors obtained.
If you have any solution, please suggest.
Thanx
vi for USB-CAN gateway
error for EPOS2
Message 1 of 1
(3,514 Views)
