Motion Control and Motor Drives
Servo Motor and NI Card
I'm pretty familiar with LabVIEW specially with the vision part of it, but I'm not familiar at all with servo motors.
Problem statement:
I'd like to make a VI that controls a servo motor that will rotate a screw every x amount of time (in both directions, obviously).
Limitations:
The screw turning should be a smooth as possible as it is a very delicate instrument and experiment.
As stated above, I don't know the first thing about servo motors and NI cards, and I would like to get some advice from you. Where should I begin? What are your recommendations for NI cards/ Motors?
I don't think that the software aspect will be very challenging, it's just two nested loops-- the first is a while loop that controls the whole experiment time and the other controls the turning function.
Unless, I underestimate to complexity of setting up a servo motor VI.
I'd be happy to hear any thoughts/ideas you might have.
Thank you,
A
(5,524 Views)
Hey A,
I would recommend using a PCI card 7332, with UMI 7772, and AKD servo drive P00606. Then you can select the motor. Depending on the size of your application, choose a motor, and then make sure that the drive has enough current to power it.
A. Zaatari
(5,502 Views)
