Motion Control and Motor Drives
Scanning mirror using Thorlabs TDC001 apt-dc servo controller
Hello. I need help with configuring a Labview code controlling a Thorlabs TDC001 apt-dc servo controller. I just need direction on which commands to use to input the parameters of the distance and repetition rate of the stage that the controller is linked to. Attached are two separate codes that myself and a colleague created for the stage. If someome can look at this and offer some helpful tips, that would be appreciated. I am now learning how to use Labview correctly.
(6,217 Views)
Hi opticsdude,
I would recommend taking a look at motion examples in the NI Example Finder (you can find this by going to Help>Find Examples in LV).
You can also take a look at the NI Motion Help here
(6,189 Views)
