Motion Control and Motor Drives
取消
顯示結果
搜尋替代
您的意思是:
Recommendation which hardware would be best
I have a reed-switch telling me via voltage-spike when the control magnet is near. the reed-switch position and the control voltage can be freely chosen. This control circuit is then supposed to switch on the main circuit driving the main coil. So I have just have to read out the reed-switch "on" and "off" status and then switch on one of the relays with a certain delay and for a certain amout of time.
I want to use the NI-hardware to do tweaking on the timing, i.e. adjust firing of main circuit in relation to rpm (initiation, duration,...). It works kind of like commutator in a standard motor.
I thought about the NI-USB-6525. It features 8 digital input lines and 8 fast relays. So is my understanding right, that the digital input is able to interpret the reed-switch as "on" and "off"? Or do i need a analog input for this (unfortunately I didnt find a analog box in combination with the relays) ? And is the hardware fast enough as this motor is supposed to reach some rpms?
Which hardware would you recommend for the described task?
Thank you very much !!
Alex
0 積分
1 條訊息(共 7 條)
6,325 檢視
Not sure what "fast enough" means, but you will have to monitor the input line in a program, and apply your timing to it, then turn on an output.  The 6525 has solid state relays, but they can not be switched quickly.  They are limited to 5 writes per second.
0 積分
2 條訊息(共 7 條)
6,317 檢視
Ah I see. I thought the 5 per second could be reduced by reducing the duty cycle. So i guess its better to go via analog input to read in the reed-switch and analog out to switch on a transistor driving the main coil? 200kS/s should be fast enough even for 2000rpm. Maybe a myDaq can do the job for first testing?
0 積分
3 條訊息(共 7 條)
6,303 檢視
Hi Alex,
why don't you call in at NI with your requirements and ask for a device fitting your needs. They have a better overview of all devices they have in stock and can give you a recommendation.
Here you find the right number:
http://sine.ni.com/apps/utf8/nicc.call_me?p_source=contactni
Kind regards
Heinz
0 積分
4 條訊息(共 7 條)
6,289 檢視
Hm gute Idee, Danke!
0 積分
5 條訊息(共 7 條)
6,276 檢視
Gerne - You're welcome.
0 積分
6 條訊息(共 7 條)
6,267 檢視
LOL 表情 ...sorry, that happens when you're in a rush
0 積分
7 條訊息(共 7 條)
6,265 檢視
