Motion Control and Motor Drives
Querying the SoftMotion table size programmatically
Is there a way to obtain the size of a table buffer (as in the total capacity, not the "Space Available") at run-time?. I'd like to benchmark different buffer sizes + sample rates, and I'd like my timers to adapt whenever I change one of the quantities.
Alternatively, I could create a control and change it manually whenever I change the buffer size, but it would be nice to have it automated 🙂
Thanks!
Certified LabVIEW Developer
(5,884 Views)
Hey,
You can use the configure table dialog box to pre-define an empty table buffer with the desired amount of points.  Also you can dynamically update the table using the update points method.
Isaac S.
(5,863 Views)
Thanks for replying, Isaac!
After I use the "configure table" dialog box to pre-define the number of points in my buffer, is there a way to get this pre-defined number at run-time? (e.g. is there a read-only Property Node that returns the number of points that the buffer can hold?)
(5,855 Views)
Hmmm I doesn't seem like there's a property with that functionality, however I'll have to dig further in the matter.
Isaac S.
(5,844 Views)
Thanks for looking into it. Please let me know if you find something!
(5,833 Views)
