06-18-2007 09:52 AM
06-18-2007 10:13 AM
You have a PCI-7344 controller, and you are not able to initialize, that what I understand from your message. First of all the sequence of right installation is as follows:
1. Install Labview
2.Install MAx
3.Install NI-Daqmx7.3 or later
4. Install NI-motion driver
5.Install the hardware, and you must be connected to the internet, so the software will be installed automatically.
6. Also try to update firmware, by updating the ni-motion driver, and then go to MAX and click PCI-7344, and then in the right window click the firmware tab, and then click update firmware.
And see the result.
06-18-2007 11:40 AM
06-22-2007 03:29 AM
MAx 4.1 or 4.2, and NI-DAQmx7.3 is good, but for me I use 8., but that will ni affect any thing, I think NI-DAQ7.3 will be better for you since you use LabView 7.0, and inform me if there is any progress
Have a nice day
06-22-2007 04:51 AM
05-04-2011 09:34 AM
I am having the same problem with FW-7344 not showing up in MAX. I have labview 2009, NI-Motion 7.0 and MAX 4.6 running on WinXP. Any suggestions? I hope I do not have to uninstall and then reinstall everything...
05-05-2011 05:54 PM
Hey aaajones,
You can try upgrading to NI Motion 7.1. It seems that Motion 7.0 and the FW-7344 have a compatibility issue in certain cases.
If the same thing happens in 7.1 please see following KnowledgeBase Article titled FW 7344 Not Detected in Measurement & Automation Explorer with Motion 7.1 or Later.
Ricky Van De Graaf
Applications Engineering
