Motion Control and Motor Drives
PCI-7730 does not sequentially move motor different directions?
I have a 7330 motion control card that I am trying to drive one axis at a time on (so only ever 1D moves). I need to be able to move in both directions, which is easy enough to do using a modified (modified to include limits and home) example VI (I think it was the straight line 1D motion example). To effectively run my stepper motor for my application, in step/direction mode, when moving to the negative step direction (for me this is to the "blue" in my dye laser) I need to overshoot and then come back so that the motor always ends a move by coming to the red. I have tried several solutions to this problem, including:
1. in one VI copy/paste the necessary motion sub-VIs in sequence, but specify a "number of steps to move" for the second piece
2. call sequentially the same sub-VI (so rather than one long VI, a VI with calls to a main motion sub-VI) with various implementations of delays and sequencing
The problems I encounter are as follows:
When using a single move VI (so go only one direction until move complete), I can almost always successfully move, whether to positive or negative direction. Occasionally, and mostly when attempting to move in a different direction than the previous move, the motor isn't driven. I can watch this on my oscilloscope by monitoring the steps returned by the motor. The steps start, but about 4 pulses in, the VI quits with no error reported (and with the output I call for, it appears that the program thinks the move is successful). In contrast, when using the VI that calls one direction and then the other I can *never* get the second (opposite direction) move to happen. I've even put in 20s delays between the two in a flat sequence structure to no avail. However, I can move one direction and then immediately the same direction successfully with the exact same code.
I cannot find a "clear channel" or the ability to independently set the direction behavior (for instance, set direction output for a negative move before the negative move, then reset for a positive move before the move is actually called for). It is entirely possible I am missing some crucial part in my main motion VI, but then I would think that the repeated single direction moves would fail more frequently.
Is there a way to set the direction before a move? Or has someone else encountered this problem and found a more 'elegant' solution?
Thanks!
A. Berke
Of note: in order to generate enough current to drive my motor driver (it has optically isolated inputs), I have added my own resistors to both the step and direction wiring as they head out towards the motor driver.
(4,584 Views)
Accepted by topic author aberke
I've solved this in case anyone else has a similar problem. It turns out that you have to be careful with Board ID. It can only be called once (so multiple calls to sub-VIs that utilize the same Board ID in a 'main' program won't work unless the ID is passed from the top level) in a program.
(4,529 Views)
