Motion Control and Motor Drives
NIMC_DSPC Communication Error (70095)
When I try to initialize a PCI-7340 motion controller board using MAC (v4.5.0f0), I recieve the following error at Progress = 6%:
Initialization Status...
-70095 (NIMC_DSPCommunicationsTimeoutError)
Internal error. There was an internal timeout while sending commands to the DSP.
Is this something I can fix in software, or is this a hardware problem?
David Senseman
Message 1 of 9
(5,250 Views)
Hi Biologist48,
I believe this KnowledgeBase article will help you out: Error -70095 (NIMC_DSPCommunicationsTimeoutError) and Error -70052 (NIMC_FPGAProgramError). Update your Motion driver and that should do the trick.
Let us know if that works out.
Jeff | LabVIEW Software Engineer
Message 2 of 9
(5,242 Views)
Thanks for the suggestion, but it doesn't seem to help. I am currently using NI-Motion 7.6 and the executable patch says it only works with v 6.2/
BTW, I recently upgraded the firmware on the PCI-7340. Since this is a brand new project, I/m not sure if the problem occurred before the firmware upgrade or after.
Here is the current firmware versions according to MAX:
68331 Firmware    7.40.3001
DSP Firmware       7.30.3001
FPGA1 Firmware   7.00.3001
FPGA2 Firmware   7.00.3001
Message 3 of 9
(5,232 Views)
Try installing NI-Motion 7.7: http://joule.ni.com/nidu/cds/view/p/id/1114/lang/en
Message 4 of 9
(5,219 Views)
Hi Biologist48,
If the update did not work, I have a couple other questions:
Did this card ever work since you first received it? Also, do you have another board that you could swap in to see if you're still getting that error?
Message 5 of 9
(5,205 Views)
Hi Jeff!
As I tried to say in an earlier posting, this is a brand new setup and I'm not really sure my PCI-7340 ever worked. I have ordered a second board (a PCI-7332) which I had hope work arrive today (Friday) but it looks more like next Monday or Tuesday. As soon as the second board arrives, I'll swap it in and see if there is still a problem.
Thanks for your help!
Message 6 of 9
(5,182 Views)
Ok, please let us know the results when you swap the other card in.
Message 7 of 9
(5,164 Views)
Hi Jeff!
The NI Motion card (PCI-7330) arrived today. After I installed it, it asked me to upgrade the firmware, which I did. After the firmware loaded sucessfully, I initialized the new without any errors.
This leads me to think think my original board (PCI-7340) might be bad.   😞
David
Message 8 of 9
(5,157 Views)
Ok, I would recommend calling in to NI Support. Let the customer service rep know it is a potential repair on your board and give them the model. You'll be redirected to the Applications department.
http://sine.ni.com/apps/utf8/nicc.call_me
Message 9 of 9
(5,145 Views)
