Motion Control and Motor Drives
My Labview 2010 have difficulty to detect the USB to RS485 interface converter
Hi there:
I want to use my labview program to control the rotation motor I have. The motor is connected with my computer through a USB to RS485 interface converter. I already can control the motor through a small software (Mac Talk) developed by the motor controller company. The technique support guy from the company also send me a Labview vi for this, however, for some reason that labview sample he send to me can work on his computer but doesn't work on mine. I tried to checked what could be the problem, then I found this labview vi cannot detect the serial port, which I assumed there is a problem for my labview program to communicate with the USB-RS485 interface converter. How should I solve this problem?
(4,919 Views)
Hi 3C
This looks like an issue setting up the serial port on your system. You will find programmers with more experiance doing this by posting your question in the Instrument Control Forums located here.
Thank You
Eric Reid
Motion R&D
(4,913 Views)
