Motion Control and Motor Drives
Motion control
hello, somebody help! I can not conection micromaster440 with library USS. I have this problem: Error 5007 occurred at(Timeout error. STX not found. Check if the inverter is connected and the communication parameters valid) Recieve_STXChUSS.vi in Recieve_ParseTelegram_USS.vi>Receive_Telegram_USS.vi>Comm_USS>RampUpTime_p1120_SET_USS.vi>Example02_comm_USS.vi
Message 11 of 12
(997 Views)
Hi Michael,
as your question is not related to the original topic of this thread, please start a new thread for your question and add some more detailed information about your system (e. g. LabVIEW version, communication interface to the micromaster440,...).As you are not referring to an NI product you shouldn't assume that everybody in this community is familiar with the device driver that you are using, so the better you document the issue, the more likely you will get a helpful answer.
Kind regards,
Jochen Klier
Message 12 of 12
(990 Views)
