Motion Control and Motor Drives
Modulo Breakpoint
I have a question about the state of the hardware signal when "Configure Breakpoint.flx" as Modulo Breakpoint and the action input is "Set on Breakpoint".
Will the physical signal stay high after the first breakpoint or is the signal set back to low if the breakpoint is reenabled in software ("Enable Breakpoint Output.flx").
Thank for any answers
(3,375 Views)
After the breakpoint occurrence, in modulo breakpoint mode the output stays high until you reenable the bp in software. Periodic and buffered breakpoints can be configured to generate pulses without reenabling them in software, allowing much higher brekapoint rates. This feature is only available on 7350 devices.
Kind regards,
Jochen Klier
(3,370 Views)
