Motion Control and Motor Drives
Maxon Motors position-hop during drive
During the measurement I have a problem with the data acquisition. I start the motor with an absolute position, where it then moves continuously and slowly over a large range. Then I start my While loop, in which the current position is read out and compared with a target position. As soon as they match, a sensor is read out and the values are stored in a text file via the memory function. Measuring time is about 20 minutes with 8000 measuring points. When I start the measurement and put the laptop aside, everything works fine. But as soon as I have other programs open (Firefox, Excel, ...) and do something there, I get quite strong measuring errors. In this case, the physical memory also goes into a critical area. Can this lead to an interruption of the communication between PC and EPOS or generally in Labview?
Message 1 of 1
(2,060 Views)
