Motion Control and Motor Drives
MG17 and Thorlabs BSC202 - trigger output upon move completion
I have a Thorlabs NRT150 stage driven by a BSC202 controller and a Labview routine running the Thorlabs ActiveX MG17 MotorControl object.
Although I can send an output trigger signal to external instrumentation on initiation of a stage movement, I can’t find a way to send a trigger signal upon completion of a move.
I would like to complete a move, send a trigger to an external instrument, move again…….etc.
Can anyone let me know if it is possible to do this?
Thanks!
(6,353 Views)
Hi Conor,
I'd like to try and give you a hand with this. Do you think I could look at the code if it isn't too sensitive in nature?
Chris
NIUK Tech Support
National Instruments - Tech Support
(6,335 Views)
Hello Chris,
Thanks a million for your assistance. I have a Thorlabs NRT150 stage, driven by a Thorlabs BSC202 controller. The bundled APT software allows the firing of a trigger output from the controller upon initiation of a stage move, see pg. 44 http://www.thorlabs.com/Thorcat/24700/BSC202-Manual.pdf . This software can also be replicated in Labview using the MG17 Motor Control ActiveX control, http://www.thorlabs.com/images/TabImages/GuideToLabVIEWandAPT.pdf.
The key node is the ‘SetTriggerParams’, which sends a signal when a move is initiated. What I need to do is to fire a trigger signal upon completion of a move, not initiation of a move. Is there any way that I can implement this in Labview?
Our code is largely confidential but I attach a snippet that may help.
Conor
(6,297 Views)
