10-05-2007 04:15 AM
10-05-2007 06:52 AM
10-05-2007 02:29 PM
10-05-2007 03:16 PM
Cut the blue wire! Or was it the green? (Just kidding)
We really need to know more about your setup. It looks like the switches are of single-pole double-throw (SPDT) style. This means that one of the wires goes to a terminal called common (COM). The other wire must go to the normally closed (NC) OR the normally open (NO) terminal. You need to tell us which one it is.
Now, presuming that the limit switch lever is pressed down when the stage travel mechanism is supposed to stop at it's limit-
If the wire was connected to NO terminal, leaving this wire disconnected will 'deactivate' the function of the limit switch.
If connected to the NC, then to 'deactive' the limit switch, you must connect this wire to the other wired connected to the COM terminal
I do not know why you want to deactivate the function of this switch. It is there for a purpose to tell the electronics controlling the motor to stop motion. You risk damaging the motor, motor driver, stage mechanism, or even a person nearby depending on what this all is without it.
Does this make any sense to you?
-AK2DM
10-05-2007 06:42 PM
10-05-2007 09:40 PM
10-08-2007 09:03 PM
10-09-2007 08:41 AM
