Motion Control and Motor Drives
I need example of MA3 12 bit Encoder (Miniature Absolute Magnetic Shaft Encoder) in LabVIEW envernment.
    I have MA3 12 bit Encoder  (Miniature Absolute Magnetic Shaft Encoder)
I desperately need  any example of this kind of encoder.  I'm truing to fine example for many weeks.   I found many example for different kinds of encoder. However I have not fine any example for Absolute Magnetic Encoder.
 In the Data sheet of the encoder, there is an equation which I don't know how to write it in LabVIEW.  See the equation for the encoder 12 bit
x = ((ton * 4098) / (t on+ t off)) -1
 If x <= 4094, then Position = x
If x = 4096, then Position = 4095
see the Data sheet
http://www.usdigital.com/assets/general/101_ma3_datasheet_1.pdf
Please help by writing simple example of this encoder.
Message 1 of 11
(7,277 Views)
Do you have some kind of DAQ device to measure the pulse width?
Message 2 of 11
(7,274 Views)
yes, I have myDAQ.
Message 3 of 11
(7,264 Views)
There are a few ways to do this, but I would use a formula node to get x, then a case statement to get position.
Message 4 of 11
(7,260 Views)
Thanks for this idea.   However I do not know where to start.   I've spent days and nights trying to fine ways to read this but I couldn't.  I I'm kind of new in LabVIEW environment .  It might be good idea if you make  a simple  example of this encoder.   I will be so grateful.
Message 5 of 11
(7,253 Views)
What are you having problems with, coding the formula or getting the pulse width(Ton,Toff) from the DAQ?
Message 6 of 11
(7,245 Views)
There are extensive help files and examples installed with Labview.
Message 7 of 11
(7,244 Views)
I've got a example  but it does not work properly. it doe nor read properly.   I think there is a problem in the way that the encoder's formula is implmented in LabView.
This is its formula in the data sheet
 Can any one find what causes the problem or correct it then attach the file this website. Please.
Message 8 of 11
(7,235 Views)
That formula leaves a lot to be desired.  I modified it to what I think it should be.  I can't open any of your VI's, since the newest LV version I have is 8.5.  Here is a VI that gives you a reading.  This give the correct answer based on their app note examples.
Message 9 of 11
(7,229 Views)
Thank you very much for this effort. The formula you wrote is better than the one I have. I test it but unfortunately the encoder still does not work.
I do not know why!
Is it because of a problem in the formula or in reading Duty Cycle and Frequency?
I do not know.
Message 10 of 11
(7,219 Views)
