Rune,
Here is the default location for the LabVIEW example:
C:\Program Files\National Instruments\LabVIEW 7.1\examples\Motion\FlexMotion\Buffered Breakpoints and HS Capture.llb
One thing to note is that you need to configure the HSC input to be routed from the RTSI connector. YOu can do this with the Select Signal VI or in MAX.
Rodger S.
