Motion Control and Motor Drives
How to interact the motor controller with loadcell via LabVIEW
Dear all,
I am kindly asking you for help to programming my Test setup which is indicated below:
I have a loadcell, motor and a motor controller, i have all the motor controller labview drivers!
The question is: i dont know how to use these labview drivers and how to interact the motor controller with the loadcell.
Please have a look at the summary of the working principle for this setup below:
While the linear stage  is running on a single axis via the motor controller ,  the linear stage touches the loadcell and  it is starting to make compression on load cell and after a specific, predefined Force, (for example 10 Newton) on the loadcell, i want to stop the motor so it does not go further, and then start to moving the linear stage at the negative direction now it will make a tensile strength on the load cell then again i will want to stop the motor controller when the loadcell reaches the predefined force (for example 10 Newton)
I read all the data sheets but it is not indicated that how to use these labview drivers, For example: How to turn the load cell’s output to an input to the motor controller? should i use “acceleration”and “set velocity” drivers next to each other? How to connect them? Doyou know any similar or exact codes? Which product should i use? (SignalExpress? Regular Labview? Control&Simulation? etc..)
Please have a look at my brand new equipments below:
Motor Controller= Newport SMC100CC Single-axis DC motor controller/driver
Motor Linear Stage= Newport MFA-CC Miniature Linear Stage DC motor
DAQ= NI USB-6343, X Series Data Acquisition
Loadcell = Transducer Techniques, GSO-100 (Tension&Compression)
Loadcell Signal Conditioner = Transducer Techniques STAND ALONE / BENCH TOP, 0 to ±10VDC OUTPUT
Thank you for reading,
Have a nice day,
Best Regards,
Kindly wisher.
(5,735 Views)
Hi Kindly-Wisher,
The Motion Driver for the Newport motion controller you are using was actually created by Newport, so for more information on that specific driver will need to contact the creators.  They appear to have a couple of examples that you can look at, if you go to the product page and download the zip file of the Controller Drivers.  As far as the X series device goes, you can find some examples of how to interact with this by opening LabVIEW and going to Help » Find Examples, and then navigating to Hardware Input and Output » DAQmx » Analog Measurements » Voltage.
(5,716 Views)
