Motion Control and Motor Drives
How can I make MG17Piezo ActiveX automated without using jog to move the Nanomax stage
Hi Mahendar,
I am currently running it in closed mode. But I don't understand what the top part of the code does. 20 divided by stepsize then adding 1 to it then truncating it to the next lowest integer. Is that part required in the code? What does it actually do?
Message 21 of 39
(3,928 Views)
I do not find 20/stepsize in code that sent to you. can you mark it in that code and send me back ?
Message 22 of 39
(3,925 Views)
I've attached the document with a red arrow pointing towards the start of that part of the code.
Message 23 of 39
(3,922 Views)
Any ideas?
Tania
Message 24 of 39
(3,918 Views)
I wrote code too many times with step-by-step improvement. I thaink, I might have written that to control the number of iterations of the for loop. If you use any other stop condition, you can just delete that.
Mahendar
Message 25 of 39
(3,916 Views)
So 20 divide by stepsize, then +1, then truncating is basically just a limit for the number of iterations? Currently my stop condition is if the position reaches 20 (which is the maximum) then the code should stop running. Is that sufficient?
Tania
Message 26 of 39
(3,913 Views)
If you are using while loop, it is sufficient.
Mahendar
Message 27 of 39
(3,911 Views)
And so if it is calculating the maximum number of iterations, this value stays the same till the code stops running?
Tania
Message 28 of 39
(3,910 Views)
Value remain same means current position is same, peizo is not performing any motion at that moment.
Message 29 of 39
(3,908 Views)
But if this is calculating the maximum number of iterations then how can it keep changing?
So for example if I choose step size to be 0.1. Then 20/0.1=200, 200+1=201, and no need to truncate because it's not a decimal number. So this number 201 is the maximum number of iterations for the while loop is my question? What is it computing?
Given that 201 is the no. of iterations, then the code inside the while loop starts running step size multiplied by number of iteration starting from 0 and until the iteration reaches 201 the loop will keep running unless some other condition is fulfilled and the code has to stop. Is this what you're saying?
Tania
Message 30 of 39
(3,905 Views)
