Roman,
Thank you for contacting National Instruments. While using a motion controller would be the recommended approach for any type of motion application, you may be able to use your DIO board to generate a TTL pulse train to control the step and direction inputs of your drive and motor. You will need to make sure that the current sinking and sourcing specification for the DIO-96 fits your stepper motor. That board is not designed to source very much current at all so this is one issue you will need to verify. Also, this board does not have any counter/timer logic that can handle quadrature encoder inputs.
Again, this digital device is probably not the best solution to control a stepper motor, but, depending on your hardware, could be configured to work proper
ly. The PCI-7334 is a low-cost stepper motion controller that can control up to 4 axes and is designed to easily accommodate these types of applications. You can browse through more information on our Motion controller boards at the following website:
http://sine.ni.com/apps/we/nioc.vp?cid=3809〈=US
Let us know if you have any more questions or comments.
Michael
