Motion Control and Motor Drives
Has anyone used the flex read buffer function in firmware 5.1.1 and why the flex configure buffer function does not match the DLL call
I first tried to configure an input buffer but I soon found out that the declaration in the FlexMotn.bas does not match the dll call or the FlexMotion software reference manuel 5.1.1 page 7-73. This does not seem to be the only problem, I can't write the content of an onboard variable into an input buffer. What I am trying to do is to write the actual position of an axis in an input buffer while an axis is in motion so I can plot this information later. Is there anyone out there that is programming a PCI FlexMotion 6C in visual basic? Thanks for anyone who can give me an answer.
(3,912 Views)
This used to be a know issue with older versions of our firmware and driver. The FlexMotion 5.1.1 f3 upgrade solves this issue cause it comes with a new .bas file. You can get the upgrade from:
ftp://ftp.ni.com/support/motion/Software/PC/FlexMotion/5.1.xf3_patch/
(3,912 Views)
