Motion Control and Motor Drives
Got #70035 watchdog fatal error
Hi all,
One of our NI PCI-7358 motion control card keeps giving me 70035 "NIMC_watchdogTimeoutError" and ask me to power off/on PC. What're possible reasons for this error and how can I solve it?
Many thanks!
(3,986 Views)
Could you please give us some more specific information?
  1. Which NI-Motion driver version are you using?
  2. What type of motion modes do you use in your application (point-to-point, blending, contouring,...)?
  3. How frequently does the error occurr?
Jochen Klier
National Instruments Germany
(3,982 Views)
I am also getting the -70035 Fatal Error.
I use an NI-7344 motion controller.  The fatal error occurs during Check Buffer.flx.  I use a buffer to list points for 3D contouring.
This error happens only when the vi is running at the same time as two onboard programs.  The programs are saved to the board with different program numbers, and one controls Axis 1 while the other controls Axis 2.  Otherwise the two programs are identical.  I never get a fatal error when I run only one copy of the onboard program.
The onboard program uses the breakpoint lines to emit a signal when the motor pass through specified points.  It includes the following vi's:
  -  Enable High Speed Capture.flx
  -  Read Captured Position.flx
  -  Configure Breakpoint Output.flx
  -  Load Constant to Variable.flx
  -  Jump to Label on Condition.flx
  -  Insert Label.flx
  -  Subtract Variables.flx
Each time I run the program, the contoured motion runs for different lengths of time before stopping on a fatal error.
I have the same questions: What are the possible reasons for this error, and how can I solve it?
Kate
(3,827 Views)
Kate,
Here are three steps to try to fix the issue:
  1. Upgrade to the latest version of the NI-Motion driver, you can download it here:
    NI-Motion Download
  2. Check that shutdown is disabled
  3. If possible, try using another motion card in the same computer with the same code to see if the problem occurs with different hardware.
Please let us know how this goes.
Luke H
(3,810 Views)
