Motion Control and Motor Drives
Firmware updating and Labview updating problems
I have labview 7.1 and I installed NI-motion driver version 7.5 , and I have NI-DAQ 8.3, my controller is PCI-7340 and I have UMI-7774, my problem that when I try to update firmware by right clicking firmware in the tree as attached in this message I can't select it since there is no choice for selecting, also when I try to update the labview7.1 to 7.1.1 the attached message was prompted
Thank you,
and GoodBye
(3,361 Views)
  1. The firmware of the MOTION interface cannot be updated because it is already up to date ! The Update Firmware button becomes only active if the card's firmware is older than the one that is installed on the disk. I'm also using NI-MOTION 7.5 and I have just checked that the firmware versions are the same than yours.
  2. No idea about the initializing problem.
  3. Like mentionned in the dialog box, do following : Control Panel >> Add/Remove Programs >> National Instruments : Software >> Modify/Remove...>>NI LabVIEW Runtime Engine 7.1 >> Repair. Repeat for LV RTE 7.1.1 if it is also listed. Because I'm using a french version of WXP, the names may not be correct.
(3,357 Views)
