Motion Control and Motor Drives
Error -70038 occurred at Property Node in nimc.fb.power.power.coordinate.vi
HI,
I created a Real Time application with debugging enabled that only makes a straight line move and then finds center (using SoftMotion function blocks). When I run the VI from the project everything works fine. When I create the executable and run the application as a start up some times it moves beyond the limit switches and I have to abort the application, it never really works as smooth as it does when ran directly from the project.
I simplified the application. When connecting to the executable ( Operate>>Debug Application or Shared Library...)
I saw that sometimes I was getting an error that said the find center function could not be executed because the driver was not enabled. This was never needed when running from the project. I added the Power SoftMotion block and I enabled the driver before getting into the while loop that finds center. Again the VI ran without errors when ran directly from the project, but when I connected to the executable I found the following error coming out of the Power SoftMotion block (the name of my VI is: "Testing SEND to ZERO by itself.vi"):
"Error -70038 occurred at Property Node in nimc.fb.power.power.coordinate.vi --> Testing SEND to ZERO by itself.vi
Possible reason(s):
Motion: An unexpected error has occurred internal to the driver. Please contact National Instruments with the name of the function or VI that returned this error"
I am using cRIO 9022 as a controller and two 9512s.
LabVIEW 2009
NI-RIO 3.2.1
SoftMotion
Any idea why the VI works fine when ran directly from the project but does not work as expected when ran as a stand alone application directly on the cRIO?
Fab
For an opportunity to learn from experienced developers / entrepeneurs (Steve, Joerg, and Brian amongst them):
Check out DSH Pragmatic Software Development Workshop!
DQMH Lead Architect * DQMH Trusted Advisor * Certified LabVIEW Architect * Certified LabVIEW Embedded Developer * Certified Professional Instructor * LabVIEW Champion * Code Janitor
Have you been nice to future you?
(4,304 Views)
Fab,
Haven't seen an error like that yet. Are you using the latest service pack for SoftMotion (2009 SP1)? I highly recommend upgrading if not. FYI - this upgrade does not require you to upgrade to LabVIEW 2009.1.
Marc
(4,291 Views)
Marc,
When I simplified my program, I forgot to put the Power Function block inside a loop and make sure I was sending a pulse for the execute input. I am guessing that could have caused the weird error.
If I see it again, I will let you know.
Fab
(4,285 Views)
