Motion Control and Motor Drives
Error-2147352567 The specified printer is invalid
           I have designed a PrinterControl.vi use the funcitions at the Report Generation subpalette. And I have installed two virtual printers in my computer.The name of one is VirtualPrinter0,the other is VirtualPrinter1.While I use Print Report.vi ,I want to use a case struction to wire a printer name in order to realise printer selection function.When I select VirtualPrinter1,the vi can work properly.However while I select  VirtualPrinter0,I get Invalid printer name error( Error-2147352567).
        Strange still ,when I use the two printers separately,the vi can also work well.I am working with Labview 7.1.I don't know What the problem is.Hope to get help,thanks in advance for your help.
                  kivi
(4,038 Views)
Hi kivi,
If the two virtual printers could both be used in the same VI, I think it should have no problem to add a case structure.
It's a bizarre problem. Could you attach your VI?
(4,030 Views)
hi,LiMing
 First of all,   I  really appreciate your help! The  vi and the outcome  are  attached in the inclosure .Thanks again for your help!
(4,024 Views)
hi,LiMing
 First of all,   I  really appreciate your help! The  vi  is attached in the inclosure .Thanks again for your help
(4,022 Views)
