Motion Control and Motor Drives
Encoder resolution from bit to Cycles/revolution
The resolution of a speed encoder is marked as 60-bit.  Can someone please tell me what this means and how I can convert this into cycles/revolution? Thanks
(4,168 Views)
Although unconventional to most everyone, the "60 bit" means 60 pulses per revolution.
(4,156 Views)
Brian,
I have never heard about this nomenclature. ItÄs really strange and potentially misleading... What do you mean by 60 pulses/rev? Is this 60 counts/rev or is it 60 lines/rev which would result in 240 counts/rev with an X4 decoding?
Jochen
(4,139 Views)
Jochen-
I agree this is misleading.  I would suggest that the manufacturer of this device be contacted to verify this, but it is more than likely a straight 60 pulse per revolution device.  Since this was designed for speed detection, I doubt that it is quadrature.
Brian
(4,132 Views)
Who is the manufacturer and what model number is the encoder?
(4,123 Views)
