Motion Control and Motor Drives
Create a seperate home/zero button from MG17 Motor activeX box
Dear All,
There is a Home or zero button in the MG17 motor activeX control box. I need to create a seperate start work similary like home or Zero button in LabVIEW front panel and once I click on this button the motor will start moving or running. Could you please help to sort out this problem. Please find the attachement for clearifying my problem.
M.S. Mahmud.
(5,750 Views)
I don't have any experience with this ActiveX control, but you probably should be able to access this function through one of the control's  property or a method. Maybe you need to get a reference of a more specific class first, but this should be documented by Thorlabs.
Kind regards,
Jochen Klier
(5,732 Views)
I have modified your vi where is attachment, I think it will be run properly.
(4,658 Views)
