01-22-2013 04:14 PM
I have a XY stage which I can control using mach3 software. I want to control a signal generator, VNA and the XY stage at the same time. I have programmed SG and VNA using Labview but I am having difficulties controlling XY stage using Labview. I have never controlled an instrument connected through parallel port using labview.
Can anybody give me some ideas to start with? How do I use VISA to control the parallel port? I really appreciate your help. Thank you in advance.
01-23-2013 09:26 AM
Hi srms,
Since your question is related to using VISA, I would try posting your question on the Instrument Control Board. You're likely to have better luck there.
