11-26-2017 11:50 PM - edited 11-27-2017 12:10 AM
I have a project to control 4 stepper motors for a 4 axis 3D printer. I know using soft-motion one can control the motors by defining the axes. But I want to use my-Rio for this purpose. I am not sure that my-rio can handle all 4 axes. With my-rio, it gives me two options either simulated axis or unbound axis. I don't know what is unbound axis and how to assign particular DI/O pin to each axis? I saw many examples for c-rio but it doesn't explain which pin is corresponding to which axis. If I knew how to assign pins to motor then I would be able to assign my-rio DI/O pins to the example code.
Can somebody help me out with this problem?
Kashish Dhal
Solved! Go to Solution.
11-28-2017 09:11 AM
I think this is partially solved in thread
Kashish, let me know if the examples worked, please.
PedroR
