Motion Control and Motor Drives
Control of Linear Actuator using USB 6341
Can I use USB-6341 to control a Newport LTA-HS actuator for simple linear motion. How would I go about doing this?
http://search.newport.com/?x2=sku&q2=LTA-HS
Please explain in simple terms.
(5,725 Views)
Vedant,
It appears that the Newport LTA-HS actuator utilizes a simple DC stepper motor.  This means that you will need both a step and direction output from the USB-6341.  You should be able to do this by sending pulse trains, but how you send those trains is going to depend on what your motor is expecting to receive (which you may have to do a bit of research on).
If you search digital pulse train on the community portion of our website, there should be numerous examples of how to code them up in LabVIEW.  Even so, here is an example that would be pertinent to what you are trying to do:
https://decibel.ni.com/content/docs/DOC-12165
Writing a set of pulse trains to control your actuator will most likely not be easy simply because it will be dependent on what sort of commands the actuator is expecting.  In order to determine those, you can either get in contact Newport or try to find it in the user manuals for the device.
Keith M.
Applications Engineering
(5,708 Views)
