Motion Control and Motor Drives
Connecting Yaskawa Sigma II Servo Drive (SGDH) to PCI-7344 and UMI-7774
I have  NI PCI-7344 and UMI-7774 and i want to
Connect the UMI-7774 to Yaskawa Sigma II Servo Drive (SGDH) , the servo motor drive is connected to the servo motor with original Yaskawa cables.
1.  do you know if National instruments provide special cables to connect the UMI-7774 to the Yaskawa Sigma II Servo Drive (SGDH) ?
     i know there is special cable to connect this servo drive to the NI PCI-7390
     http://zone.ni.com/devzone/cda/tut/p/id/5908
    (you can find in this link that this cable exist: 50 Pin cable for connecting MCA-7790Y to Yaskawa Sigma II Servo Amplifier)
     but this is not the case here, i need to connect the Servo Drive to the UMI-7774..
 2. Where can i find a tutorial on how to configure the PCI-7344 in MAX to send simple commands to the Servo Drive
      i.e.  to run the servo motor from position A to position B (10,000 encoder pulses)
i'll be gratefull for any help
Regards
Moti
(4,098 Views)
Hi MotiM,
We do not have a cable that will let you directly connect the UMI-7774 to a Yaskawa Drive.  We do sell cables that will have the Dsub connector to match the UMI-7774 with pigtails to wire to the drive.  If you take a look at the product page for the UMI-7774 you can see the different cables listed under the accessories.
To perform a simple move in Measurement and Automation (MAX) is very simple.  In MAX under NI-Motion select your PCI-7344. Under this section select the settings option (by default it will be called Default 7340 settings).  Select the Servo radio button.  Initialize your controller.  Then you can select Interactive and 1-D Interactive and command your motor from there.  I have attached an image with the important areas highlighted for you.
Message Edited by Adam_H on 09-19-2008 03:41 PM
Adam H
(4,080 Views)
Dear Adam,
Thank you for your reply.
i'll read the hole manual and learn how to configure it.
Thank you.
Moti
(4,070 Views)
