Motion Control and Motor Drives
Commutation with 6280 DAQ Card
I want to perform parameter identification of a three phase brushless DC servo motor. Basically I want to obtain mass moment of inertia, viscous damping coefficient and coulomb friction at the bearing. To do so, I plan to apply a step voltage input to the motor terminals and collect the position information with a DAQ card. I know the inductance and resistance values of the motor windings as well as the I want to perform parameter identification of a three phase brushless DC servo motor.
I know the inductance and resistance values of the motor windings as well as the torque constant of the motor.
So when I apply a step voltage input to the terminals of the motor, I would know the torque that is applied.
And since I know the torque that is applied and also collect the position data I would be able to plot torque vs. position curve and would be able to obtain the necessary parameters from this graph.
My problem is; I don't know how i can apply a step voltage input to a three phase brushless DC motor.
Is it possible to use a DAQ card (I have a PCI 6280 DAQ card) for commutation? If it's possible is there an example about commutation of brushless dc motor?
I don't want to use a motion control card to perform the commutation since I want to observe the motor dynamics only.
Regards.
(3,499 Views)
for commutation you need to synchronize the output signals to the absolute rotational position of your motor. Typically this is done by implementing a lookup table to output values according to the motor's angle of rotation. This operation requires deterministic real-time behavior, so you could use a DAQ board with LabVIEW Real-Time, but for your application an FPGA-based R-Series device is probably a much better choice.
Instead of generating analog output signals, with an R-Series device you could directly generate PWM signals with sinusoidal duty cycles to control an external FET amplifier.
Here you can find example code for such a setup.
I hope this helps.
Kind regards,
Jochen Klier
(3,497 Views)
