01-03-2008 02:38 PM
01-04-2008 02:26 PM
01-04-2008 03:59 PM
Thanks Rishi,
Sorry, I am using aPCI-7344, although I am only using the first Axis. I have been working through isolation issues on this test setup for some time and check isolation with a Fluke DMM. What I found to alert me to the "leak" is a potential of about 300 mV from the computer chassis ground on the AO signal at the servo controller. Based on your reply, it will be easiest to just a ISo124 isolation amplifier on the analog output, but will require a couple of DC/DC converters to handle the polarity changes. Thanks for your help.
-Stefan
