Motion Control and Motor Drives
Can I load velocity real time?
If you see a lot of noise in a velocity plot, this is typically not caused by real physical oscillations of the axis' velocity but by the way the board measures the velocity. To measure the velocity basically the board counts the encoder counts per PID cycle and divides the value through the PID cycle time. As the PID cycle is pretty fast, especially at low velocity values you might see significant noise caused by this math.
E. g. if your axis travels with 4.5 counts/PID cycle period, the value jumps between 4 and 5, which looks like a 25% velocity oscillation in a velocity plot even though the axis moves perfectly smooth.
With this said, the real velocity measurement algorithm on NI motion control boards is a bit more sophisticated and it provides a filter to improve the accuracy of the velocity measurements. In LabVIEW you can use "Load Velocity Filter Parameter" to adjust the operation of this filter to your needs. The filter should help you to get better results, but due to the discrete nature of the position feedback it won't resolve the issue completely.
Kind regards,
Jochen Klier
Message 11 of 20
(2,264 Views)
Jochen,
I'm going to try "Load Velocity Filter Parameter". And see what it happens.
One more question, how can we caculate the time elapsed in motion loop?
Thank you!
Guangli
Message 12 of 20
(2,241 Views)
Hi, Jochen,
One more question again. I also want to feedback the velocity of braiding point to motion loop. As it was shown in previous screenshot, I will use (previous position minus current position) divid by elapsed time. Shall I use for loop and formula? I'm not sure how to use it in LV. Can you give me some clue or example?
Thank you very much!
Guangli
Message 13 of 20
(2,238 Views)
Also, velocity feedback is like position feedback before in realtime. So, it will output one value every time.
Thank you!
Message 14 of 20
(2,236 Views)
Guangli,
unfortunately I have some problems in understanding your questions, but I'll do my best to answer them:
How can we caculate the time elapsed in motion loop?
The onboard timing of the PID loop is always stable and you can set the cycle time in MAX. If you are referrring to the timing of the LabVIEW loop, you could use a timed loop, which provides more advanced timing features and information about loop cycle times.
As I don't know your application, I can't give you detailed advice here. The usage of formula nodes is always recommended if your math involves more than 2 or 3 calculations. In such cases formula nodes make the code more readable.
Is this a question?
Jochen
Message 15 of 20
(2,224 Views)
Jochen wrote:
Guangli,
A: I mean the time code running costed. Can I set some vis to get the time?  I will check the cycle time in MAX, too.
A: Don't worry about this one.
Is this a question?
A: That's the condition of code running.
Just help me first question.
Message 16 of 20
(2,221 Views)
Hi Guangli,
I'm sorry but we have a little communication issue here. I really don't understand exactly what you are looking for. Do you want to measure the execution time of your code inside a loop? This can be done by taking a time stamp (e. g. with "Tick Count (ms)") before and after the execution of the code in your loop and substract the values. As already said, the timed loop provides this information by itself. By the way, timing loops is mandatory. Loops without timing typically consume100% of CPU power and may result in unwanted behavior.
The cycle time in MAX is the onboard cycle time of the PID loop. There is no link between this cycle time and the code execution time in LabVIEW.
Jochen
Message 17 of 20
(2,210 Views)
Hey, Jochen,
I truly want to execution time of my code inside a loop. I will try time stamp.
For my code, I also have image processing loop, which is faster than Motion loop. So I want execute my code as soon as possible. That's why I want to fine what's the execution time exactly.
Thank you!
Guangli
Message 18 of 20
(2,204 Views)
Hey, Jochen,
One more question. Do I need to add the electronic gear in my code if I have gear train in my experiment?
Thks!
Guangli
Message 19 of 20
(2,199 Views)
Hi Guangli
with electronic gearing you can synchronize multiple axes or you can synchronize axes to moving parts that are equipped with a quadrature encoder. Electronic gearing has nothing to do with a physical gear train. You can find more information about electronic in the NI-Motion manual.
Jochen
Message 20 of 20
(2,177 Views)
