first thank you for your concern my question
my application is six axes monitors, every two axes motors do the same motion. I meam the two axes motors connect to the one system they have move synchronously with the same velocity . just use the two motors do the job like using one motor. NOW I use umi 7774,it has for axes interface. I want to use one axs interface to control the two motors, I mean through the one axs inerface send the same control signal to the two motors. then I can use the three axes interface of the umi to control the six axes motors multiple motion
IN FACT, my application is simple, I mean the six axes montiors every two axes motors is one group and do the same motion . and the motion is straight-line just front and back.
other two groups motion trace is also straight-line , what I need to do is control the three group motiors move following the set schedule,velocity and position SO the three group monitors do the straight-line motion at different schedule ,velocity and position. but from the labview program I HAVE TO PROGRAM TEH LABVIEW CODE IN THREE-D MODE AND I CAN CONTROL THE THREE GROUP MOTORS OR THERE IS SOMETHING ELSE WAY TO SETTLE MY QUESTION??? HOW I CAN SET THE DIFFERENT VELOCITY IN THE THREE GROUP MOTIORS. AND I FOUND WHEN YOU SET THE VELOCITY IN LABVIEW ,YOU JUST SET ONE VELOCITY , I NEED THE THREE DIFFERENT VELOCITY TO THE THREE GROUP MOTORS, HOW DO I PROGRAM???
I AM LOOKING FORWARD TO YOUR HELP
