Motion Control and Motor Drives
780068-01 NI NEMA 17 Stepper Motor dual shaft - recommended encoders?
Does NI have any recommended encoders to go with the new stepper motors being offered?
I am looking at the above listed part number for a motion project and want closed loop control.  Thank you.
Ryan
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(5,488 Views)
Accepted by topic author RVallieu
Hi Ryan,
Thank you for posting to the National Instruments discussion forums.
For the NEMA 17 Stepper Motor, we recommend the HEDS-55xx family of encoders from Avago (Agilent).  You can purchase these from US Digital:
http://www.usdigital.com/products/avago/heds-e2.shtml
When choosing your encoder, please keep in mind that the shaft diameter for the NEMA 17 Stepper Motor is 5 mm.
Thank you again for your interest in our products, and good luck with your application.
Rishee B.
Message Edited by risheeb on 11-16-2007 12:24 PM
(5,464 Views)
What is the recommended mounting option for the NI motor encoders suggested?
Thank you.
(5,439 Views)
Hi Ryan,
The NEMA 17 Stepper motor has a 3-screw encoder mount configuration, which is standard for the Avago HEDS-55xx encoder as well.  The mounting ears option for the encoder should not be necessary with this motor.
Also, you will want to make sure you purchase the dual shaft option for the NEMA motor.
Rishee B.
Message Edited by risheeb on 11-20-2007 07:47 PM
(5,416 Views)
Seems like US Digital no longer sells the Avago encoders - they have their own line now...
E2 and E5 from US Digital can replace the HEDS-55xx series Avago
(3,605 Views)
