Measurement Studio for VC++
rewrite the buffer for continous analog output
Dear forum-users,
I am using a PCI 4461 and I program it with Visual C 6. I want to realise a continous buffered output with it, putting continously new samples into the buffer. Does anybody know how to write samples to the buffer without stopping the task?
The continous output I realise like this:
#include <NIDAQmx.h>
#include <stdio.h>
#include <math.h>
#include <time.h>
#define DAQmxErrChk(functionCall) if( DAQmxFailed(error=(functionCall)) ) goto Error; else
float64 data[2];
int32 CVICALLBACK DoneCallback(TaskHandle taskHandle, int32 status, void *callbackData);
int32 CVICALLBACK EveryNCallback(TaskHandle taskHandle, int32 everyNsamplesEventType, uInt32 nSamples, void *callbackData);
int main(void)
 int32       error=0;
 TaskHandle  taskHandle=0;
 int32       write=0;
 char        errBuff[2048]={'\0'};
 int         i=0;
 clock_t  tic,toc;
 double  dauer;
 for(;i<2;i++)
  data[i] = 1.0;
 // DAQmx Configure Code
 DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
 DAQmxErrChk (DAQmxCreateAOVoltageChan(taskHandle,"Dev1/ao0","",-10.0,10.0,DAQmx_Val_Volts,NULL));
 DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",1000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,2));
 DAQmxErrChk (DAQmxRegisterEveryNSamplesEvent(taskHandle,DAQmx_Val_Transferred_From_Buffer,2,0,EveryNCallback,&write));
 DAQmxErrChk (DAQmxRegisterDoneEvent(taskHandle,NULL,DoneCallback,NULL));
 DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,2,0,10.0,DAQmx_Val_GroupByChannel,data,&write,NULL));
 DAQmxErrChk (DAQmxStartTask(taskHandle));
 tic=clock();
 printf("Generating voltage continuously. Press Enter to interrupt\n");
 getchar();
Error:
 if( DAQmxFailed(error) )
  DAQmxGetExtendedErrorInfo(errBuff,2048);
 if( taskHandle!=0 ) {
  // DAQmx Stop Code
  DAQmxStopTask(taskHandle);
  DAQmxClearTask(taskHandle);
  toc=clock();
  dauer=(double)(toc-tic)/(double)(CLOCKS_PER_SEC*1e-3);
  printf("\n%f ms",dauer);
  printf("DAQmx Error: %s\n",errBuff);
 printf("End of program, press Enter key to quit\n");
 getchar();
 return 0;
 int32       error=0;
 static int  totalwrite=0;
 // DAQmx Write Code
 if( nSamples==2 )
  printf("\noutput %d samples. Total %d\r",nSamples,totalwrite+=nSamples);
  fflush(stdout);
 return 0;
 int32   error=0;
 // Check to see if an error stopped the task.
 DAQmxErrChk (status);
Error:
 if( DAQmxFailed(error) ) {
 return 0;
The callback I use to see, that the desired numbers of samples has been output.
Thanks a lot for your help,
Hanna
(6,023 Views)
Hey There,
I found the Answer: DAQmxGetWriteSpaceAvail(...)
Hanna
(6,009 Views)
