Measurement Studio for VC++
problem with converting from CString to char*
hello people,
I try to cast a CString in char* but it only take the first character
CString sox =(CString)"A060,"  ;
char* pChar = (char*)(LPCTSTR)(CString)sox ;
after i built it, there is only the character "A"  in pChar and not "A060,"
HELP !!!!
(5,338 Views)
What do you use to display pChar?
As pChar is pointing a Cstring, you have to display it as a CString.
If you use a printf it will display A, you have to use _tprintf.
source: https://msdn.microsoft.com/en-us/library/ms174288.aspx
Example:
int main()
    _tprintf(_T("char=%s\n"), pChar);
Result:
char= A060.
Jovan N. - Application Engineering
(5,192 Views)
