Measurement Studio for VC++
ni-visa msvc sample code error: -1073807343 on viOpen() - am I missing a .dll?
Have been testing out the MSVC C++ sample code on XP with MSVC 2008 IDE for USB & TCPIP with Rohde and Schwarz power sensor and code is giving error.  Apparently, we cannot use the Passport or VXI .dll's since they only support 32-bit and we're required to work with only 64-bit compatible drivers or code.  Thus, we have to use NI-VISA + test equipment SCPI commands, and sample code is not working when we plug in sensor to USB or Ethernet ports - we get -1073807343 error on viOpen().  viFindRsrc() was working with USB, but does not now that we moved device to AnywhereUSB (TCP/USB) device.  We can't even get typical lines to work such as:
status = viOpen (defaultRM, "USB::0x0aad::0x002c::101699::INSTR", VI_NULL, VI_NULL, &instr);
Any ideas - missing a .dll or library??? (measurement studio .dll)? MSVC project setting?
Thank you to whoever can figure this out...
(6,372 Views)
Hi Kay77,
Could you clarify what you mean by working with only 64-bit compatible drivers or code? What operating system are you currently on?
Best Regards,
Swathi B
(6,348 Views)
