Measurement Studio for VC++
how to create CNiFieldPointNetwork module in Multithreaded apartment
Hi thatsalok,
Since CNiDataSocket encapsulates the NI-DataSocket interface (simply a c++ wrapper around the CWDataSocket ActiveX object), you need to be using the interface IDs found in the type library for the CWDataSocket object. Use the OLE/COM Object Viewer to look up this information. Once inside the viewer, expand the Type Libraries category and navigate to National Instruments CW DataSocket. This should provide you with all the information you need.
Best Regards,
Jonathan N.
Message 11 of 13
(2,864 Views)
Hello Sir,
  thanks for reply.. i have checked out what you have said.. INIDSCtl interface which CWDataSocket is encapsulating is Hidden from outer world.. as it idl says
  odl,
  uuid(A7C10FE3-E3FC-11D0-80E8-00A02454310A),
  helpstring("Connects to data sources for reading data or data targets for writing data."),
  helpcontext(0x0000289d),
  hidden,
  dual,
  oleautomation
..  now how to create instance of same from outside world i.e. from my application..
Thanks and Regards
Alok
Message 12 of 13
(2,859 Views)
thanks of lot.. i got it ..
 i used following method and it is working for me
CLSID clSid;
CLSIDFromString(L"CWDSLib.CWDataSocket",&clSid);
INIDSCtl* pInidsctlPtr;
CoCreateInstance(clSid,NULL,CLSCTX_ALL,__uuidof(INIDSCtl),(LPVOID*)&pInidsctlPtr);
Message 13 of 13
(2,858 Views)
