Measurement Studio for VC++
add/call a VC++ .NET to labview
Hi everybody,
Can somebody guide on how to add/call a VC++ .NET code for accquiring real time data in Labview to do data processing oa the accquired data?
I have build in VC++.NET the code which accquires the data in real time and this is called for by computer 2 using the VC++.NET developed. Iam looking to add this code to labview to process these data  for feedback and at the same time create a user friendly layout.
Thanks in advance
(6,452 Views)
There are different ways to call your .NET code depending on what you are doing.  You can call a DLL into LabVIEW using a Call Library Function Node or you can use the .NET LabVIEW functions to interface between the two.  Please take a look at the following links:
An Overview of Accessing DLLs or Shared Libraries from LabVIEW
.NET Functions (Windows)
(6,439 Views)
