Measurement Studio for VC++
Which drivers to distribute for new device wizard for USB6008
I have an application in C++ using NI-DAQmx for the USB6008 device. (This is not really using Measurement Studio but was the closest option offered in this help forum). I would like to make an installation disk for my application and need to know how to present the device drivers to the new device wizard on an XP machine.
Which driver should I use and can I just point the wizard to that driver?
(3,248 Views)
Hello Western,
The USB 6008 uses the DAQmx Base driver. All you have to do is install the DAQmx Base driver which can be downloaded here:
http://digital.ni.com/softlib.nsf/websearch/CE3686A8D5B0CEDC86256FFD007C9C4A?opendocument&node=132060_US
When you plug in the USB 6008, the Windows XP New Hardware Wizard will detect the device, and will "know" the appropriate drivers for the device.
I hope this helps!
E.Lee
Eric
DE For Life!
(3,240 Views)
