Measurement Studio for VC++
Using autoscale of x axis, how do I get my data to fill the graph plot area?
Hi there
I'm plotting a graph in real time, and data is getting to several different plots. When fresh data comes in for a particular plot, say plot 1, I call ChartY(xAmountToIncrement, YValue). At the same time, I update all other plots so they all remain at the same x value. I call ChartXY(xAxisTotalValue, plotYValue).
My problem is that I lose data as the graphs plot along the x axis - I have no idea why, but data from the past is lost.
My x axis is set to autoscale, which means that point 0 is soon lost as the x axis reflects milli-seconds. By the time the plot gets to 5 milliseconds through to 10 milliseconds, x axis data is only shown from say 7 milliseconds through to 9.5 milliseconds.
Why am I losing data and how can I keep it there? I know I can't use the chartlength property as this will only compress the data as point 0 remains fixed on the graph.
Thanks for any help!
(6,191 Views)
Hi
Can you post an example of the code you are using - perhaps with a file or pre-defined array to give the impression of data coming in?
I'm not sure I fully understand what you are saying when you say data is lost so it would be helpful to have something to run and observe the behaviour of?
Regards
Hannah
NIUK & Ireland
(6,162 Views)
