Measurement Studio for VC++
Traditional daq pci-6534 , working with double buffer
hi,
I am working with traditional daq pci 6534
The main goal is to acquiring enormous size of data for a certain time interval,
For this I am using the double buffer and when "DIG_DB_HalfReady(iDevice, iGroup, &iHalfReady)"
When iHalfReady == 1 I get half the buffer,
After a period of time, I would like to retrieve the data from the NI card, the size of the data in the NI card is less then half buffer size.
How can I do it???
(3,256 Views)
Have you tried the DIG_Block_In function?  If you are able to read the number of points in the buffer with the DIG_Block_Check function, you should be able to feed that value into the DIG_Block_In function to pull the data out of the buffer.
Please try this out and let me know your results.
Sean C.
(3,243 Views)
