Measurement Studio for VC++
PCI GPIB using Qt Creator under Windows
I'm trying to communicate with a PCI GPIB board.  The application I need to use is developed in Qt Creator under Windows.  After searching the NI website, I can't figure out which DLL and/or header files I need to get to do this.  All I've found are pre-compiled object files to link against using some versions of Visual Studio.
(7,038 Views)
Hi Mark,
Have you tried these:
C:\Windows\System32\GPIB-32.dll
Andrew M.
(7,031 Views)
If that's all that is needed, what's the purpose of the pre-compiled object files?  Are those merely for statically linking against?  Will the DLL you specificed be all I need to access the PCI GPIB interface from a generic C++ application?
Thanks.
(7,025 Views)
Hi Mark,
I'm not sure about the answer to those questions. Let me do some research and I'll get back to you.
Andrew M.
(7,017 Views)
