Measurement Studio for VC++
NI-DAQ8.7.1 ATI DAQ F/T sample error with VC++6.0
My pc is installed NI-DAQ 8.7.1, and I am working with F/T sensor with VC++ 6.0 compiler.
As I am a new user, I download a sampler program from  http://www.ati-ia.com/products/ft/software/daq_software.aspx (Visual C++ Application)
First, when i compiled it, it was error with  NIDAQmx.lib 's path (my pc directory is C:\Program Files\National Instruments\NI-DAQ\DAQmx ANSI C Dev\lib\msvc, and the sample program is C:\Documents and Settings\Program Files\National Instruments\NI-DAQ\DAQmx ANSI C Dev\lib\msvc)
After changing its path, I could compile it well, but it was error when I run it. I do not know what the problem, it may because of xxxxxx.dll file? in system32?
Can u explain me and tell me the compiling instruction??
(7,257 Views)
软件不错
(6,444 Views)
Hi camboljp,
Thank you for using our discussion forum.
Sorry for getting back to you so late.
What is the error code you are running into? That may help me solve this problem.
Also, as I looked at the sample program you specified, I noticed that the programs use Traditional NI-DAQ software. There is a possibility that version of the driver is not compatible.
Your NI-DAQ8.7.1 is not for the "Traditional DAQ", so you may need to uninstall NI-DAQ8.7.1 and re-install NI-DAQ6.9.x or lower.
Let me know if you have any questions.
Kei Eto
(6,414 Views)
