Measurement Studio for VC++
NI 9403 Write Digital Line
I have a NI 9403 DIO card within my DAQ.  I am trying to use the write digital lines command to send a pulse whenever I need to (or whenever my code says I need to send a pulse).
The problem I am running into is the time it take between commands (approximately 10ms as the minimum).  Here is my code.  I pause between the commands for 1ms, but pauses below 10ms just result in a 10ms lag anyways.  Preferably I would like to send these commands to my card much faster, but once again, the rate can change fairly often.  Any help would be appreciated.  Thanks,
DAQmxErrChk(DAQmxCreateTask("", &taskHandle2));
DAQmxErrChk(DAQmxCreateDOChan(taskHandle2, "cDAQ2Mod4/port0/line8:13", "", DAQmx_Val_ChanForAllLines));
DAQmxErrChk(DAQmxStartTask(taskHandle2));
DAQmxErrChk(DAQmxWriteDigitalLines(taskHandle2, 1, 1, 0.0, DAQmx_Val_GroupByChannel, data, NULL, NULL));
std::this_thread::sleep_for(std::chrono::milliseconds(1);
Message 1 of 1
(1,441 Views)
